Forum Home Forum Home > Contractors talk > Contractors Talk
U4GM Bee Swarm Simulator: Boost Amulet's Strength
1fuhd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1fuhd Quote  Post ReplyReply Direct Link To This Post Topic: U4GM Bee Swarm Simulator: Boost Amulet's Strength
    Posted: 22 Apr 2026 at 8:03am
In Bee Swarm Simulator, an amulet's strength depends on two main factors: its tier and the stats the game assigns within that tier. Higher-tier amulets generally offer more capacity and stronger potential stats, while Star Amulets can also roll passive abilities that add extra value Bee Swarm Simulator Items.
Amulets are earned through activities like defeating King Beetle, completing the Ant Challenge, generating Moon Amulets, beating the Stump Snail, or progressing through Stick Bug or Robo Bear challenges. When you collect an amulet, the game shows a comparison with your current one, letting you decide whether to keep the old amulet or replace it. Stat strength isn't a single hidden number you can see—it's a combination of tier, capacity, and the bonuses that appear on the item.
For Star Amulets, the tier matters a lot. Bronze starts with x1.25 capacity, Silver at x1.5, Gold at x1.75, Diamond at x2, and Supreme at x2.5. Higher tiers also unlock more bonus lines and higher stat ceilings. Supreme Star Amulets can roll the largest values for stats like pollen, bee gather pollen, convert rate, bee ability rate, and critical chance, which is why they're usually considered the strongest general amulets.
The game also rewards players for discovering more gifted bee types. The more types you've discovered, the better your chances of getting maxed stats on Star Amulets. Supreme Star Amulets require 40 gifted bee types discovered and cost 10 billion honey, with an optional 500 billion honey spend for a guaranteed double passive. Since passives are a big part of their value, the strongest amulet isn't just about high percentages—it's also about having passives that complement your hive and playstyle.
Players usually focus on improving capacity first, then chasing the stat combinations that best suit their hive. Some amulet rolls favor general farming with stats like pollen and convert rate, while others are more specialized, such as blue or red pollen or bee ability rate. Community advice often recommends picking amulets that match your hive's strengths rather than just going for the highest-looking numbers.
There's also a difference between raw bonuses and long-term value. A Diamond Star Amulet might look strong if it has a rare passive like Star Shower, but a Supreme Star Amulet can outperform it with higher capacity and stronger stats across multiple lines. Only Diamond and Supreme Star Amulets can have passives, and Supreme is the only tier that can hold double passives. This means the best amulet is usually the one that combines solid numbers with useful passives, not just one eye-catching stat.
If you want to improve amulet strength efficiently, the key is to unlock higher tiers, keep generating amulets until the roll fits your hive, and pay attention to passives. For Star Amulets, discovering more gifted bee types directly increases your chances of better stats. At endgame, Supreme Star Amulets are the benchmark, offering the largest capacity boost, strongest stat ranges, and the most valuable passive options.
In the end, getting a strong amulet is about understanding how tier, stat ranges, and passives work together Bee Swarm Simulator Items buy. The best results come from progressing to higher tiers, maximizing your gifted bee discoveries, and choosing rolls that fit your hive, rather than chasing one perfect stat line that works for everyone.
This page was generated in 0.195 seconds.
