Forum Home Forum Home > FrameBuilder MRD > Support
Why These Silver Cards Are "Glitchy" in MLB The Sh
NightFury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NightFury Quote  Post ReplyReply Direct Link To This Post Topic: Why These Silver Cards Are "Glitchy" in MLB The Sh
    Posted: 1 hour 24 minutes ago at 4:00am
What Makes a Silver Card “Glitchy”?
In MLB The Show 26, a silver card is technically a mid-tier card, usually ranging between 70 and 79 overall. These cards are supposed to perform modestly, with balanced stats that reflect their real-life counterparts. However, some players seem to exceed expectations or behave unpredictably. This usually comes down to a few key factors:
Stat Spikes in Key Areas
Silver cards often have one or two standout stats that aren’t immediately obvious. For example, a batter might have a mediocre overall rating of 75 but carry a 90 contact rating against left-handed pitching. In practice, this can make them hit much better than you’d expect in certain matchups.
Hidden Animations and Timing Windows
MLB The Show 26 uses nuanced animations for batting, pitching, and fielding. Some silver cards have unique swing or pitching animations that are faster, smoother, or harder to time against. These subtle differences can make a card feel overpowered—or glitchy—especially if you figure out how to exploit the animation consistently.
AI Behavior in Online Modes
Some silver cards can manipulate the CPU AI in unusual ways. For example, certain pitchers may throw pitches that the AI overestimates, resulting in more strikeouts. Similarly, some batters may trigger weird fielding responses, like infielders misjudging balls more often. These quirks don’t appear in every game, which is why the term “glitchy” comes up so often among players.
Which Silver Cards Are Known to Be Glitchy?
While card performance can vary based on the exact version of the game and patch updates, some silver cards consistently stand out in player discussions and personal testing:
Mid-Tier Contact Hitters
These players might look average on paper but can have surprisingly high batting averages in practice. Many players find these hitters excel against certain pitch types, like curveballs or sliders, more than expected.
High-Velocity Relievers
Some silver relievers have pitch velocities that feel closer to gold cards. They’re difficult to hit if you’re not expecting the speed or movement.
Versatile Fielders
Certain silver fielders can cover more ground than their stats indicate. This is often due to faster animations or better reaction coding in the game, making routine plays easier and turning potential errors into outs.
Remember, these observations are based on real player behavior. Not every silver card is glitchy, but the ones that are often become staples in affordable, low-stub lineups.
How to Take Advantage of Glitchy Silver Cards
Once you identify a silver card that feels glitchy, the key is using it effectively:
Matchup Awareness
Pay attention to pitch types, handedness, and field positioning. A glitchy card might only shine in specific situations. For example, a left-handed hitter may have unusually high success against right-handed pitchers, making them more valuable in certain matchups.
Exploit Timing and Animations
Take time in batting practice or solo games to learn the swing or pitching animations. Cards with glitchy animations can be devastating once you consistently time them correctly.
Team Composition
Using glitchy silver cards in combination with high-rated players can help balance your lineup. They may not dominate every game, but they can be surprisingly clutch in key moments, particularly when resources for gold or diamond cards are limited.
Market Savvy
If you notice a silver card performing unusually well, their market price may not reflect their true in-game value. Savvy players often pick up these cards before others notice their potential.
For those looking to expand their options quickly, one practical step is to buy MLB 26 stubs ps5, which allows you to access more packs and improve your chances of snagging silver cards with hidden potential.
Common Misconceptions About Silver Cards
Not all unusual performance comes from glitches. Sometimes, players assume a silver card is overpowered when it’s actually working as intended:
Small Sample Size
A few games of good luck can make a player seem glitchy. Always test a card across multiple games to see if performance holds.
Player Familiarity
Knowing a card’s tendencies, like pitch timing or swing speed, can make it feel better than it actually is. Experienced players often exploit this, giving silver cards a temporary edge.
Patch Variations
MLB The Show 26 receives updates that can change animations, pitch behavior, and overall ratings. What was glitchy in one patch may normalize in the next.
Are Glitchy Silver Cards Worth the Investment?
In most cases, yes—if you understand how to use them. They provide affordable depth for lineups, especially in online modes where spending high stubs on gold or diamond cards may not be practical. They also offer unique gameplay experiences that help you learn timing, positioning, and strategy. However, you should always balance silver cards with higher-tier options to avoid being overwhelmed by elite opponents.
Silver cards in MLB The Show 26 aren’t inherently broken, but certain players can feel glitchy due to hidden stat advantages, animations, or AI interactions. By learning which cards perform above their rating and understanding how to use them, you can gain a noticeable edge without spending excessive stubs. Testing cards in multiple scenarios, paying attention to matchups, and strategically using them in your lineup is the most reliable way to exploit their potential. For players looking to expand their roster quickly and test out these hidden gems, it’s a practical step to buy MLB 26 stubs ps5 to gain access to more packs and find the best silver cards for your team.
This page was generated in 0.162 seconds.
