Forum Home Forum Home > FrameBuilder MRD > Support
Guide to Crafting Legendary Gear in Arc Raiders
NightFury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NightFury Quote  Post ReplyReply Direct Link To This Post Topic: Guide to Crafting Legendary Gear in Arc Raiders
    Posted: 28 Feb 2026 at 8:06am
What is Legendary Gear in Arc Raiders?
Legendary gear is the highest-tier equipment available in Arc Raiders. These items are more powerful than common, rare, or epic gear, offering significant boosts to your character's abilities. Legendary gear often comes with special attributes or abilities that can make a huge difference in both PvP and PvE content.
However, crafting these items isn’t as simple as just gathering materials. There’s a bit of a process involved, and the stakes are high since legendary gear is hard to come by. So, what do you need to know before you get started?
How Do You Craft Legendary Gear?
Crafting legendary gear requires several key steps and resources. Here's an overview of what you’ll need to do:
1. Gather Resources and Materials
The first step in crafting legendary gear is to gather the right materials. These are often obtained by completing missions, defeating enemies, or dismantling lower-tier gear. You’ll also need to gather rare crafting materials, which can be harder to come by.
Common materials include:
Common Ore – a basic resource needed for low-level crafting.
Rare Elements – special materials that are required for higher-tier gear.
Legendary Components – these are rare and hard to find, but they are crucial for crafting legendary gear.
These materials are often dropped by enemies in higher-level zones or found in caches, so make sure you’re venturing into tougher areas to gather these.
2. Unlock Crafting Stations
In Arc Raiders, you cannot craft legendary gear anywhere. You need to unlock specific crafting stations or NPCs that allow you to forge high-level items. Make sure to level up your crafting skills and complete any necessary quests to unlock these stations.
Once unlocked, you’ll have access to a menu where you can choose which items to craft, based on the resources you’ve collected.
3. Crafting Process
The actual process of crafting involves combining various materials to create your gear. At the crafting station, you’ll choose the piece of gear you want to create, such as weapons, armor, or accessories.
Each piece of gear requires a specific combination of materials, and the quality of the materials used will impact the final product. Legendary gear often requires high-tier resources and a substantial amount of time to craft.
4. Enchantments and Upgrades
One of the unique aspects of legendary gear is the ability to add enchantments or upgrades. Once you craft a legendary item, you can further enhance it by adding special attributes like increased damage, enhanced defense, or buffs to specific abilities.
These enchantments are typically found through special quests or purchased from vendors in the game. The more you upgrade and enhance your gear, the more powerful you become, so it’s important to focus on improving your legendary items.
5. RNG (Random Number Generation) in Crafting
It’s important to note that crafting legendary gear involves a degree of randomness. Not every item you craft will turn out perfect. Sometimes, even with the best materials, your gear may not have the stats you wanted.
This randomness is part of the challenge and thrill of crafting. You might get an item with excellent bonuses one time and a less-than-ideal one the next. If you’re not satisfied with your result, you can often salvage the item for materials and try again.
What Are the Challenges in Crafting Legendary Gear?
Crafting legendary gear is not without its challenges. Here are a few things to consider:
1. Resource Management
Legendary gear requires a lot of materials, and some of them can be hard to find. Balancing your resource gathering with your other priorities in the game is key to crafting efficiently. Make sure to manage your resources carefully and focus on farming the materials you need most.
2. Time Investment
The crafting process can take time, especially for legendary gear. You can’t rush it; you'll need to spend a lot of in-game hours gathering materials and upgrading your gear. Be prepared for a time-consuming grind, especially if you’re aiming for the highest-quality legendary items.
3. High Costs
Crafting legendary gear can be expensive, both in terms of in-game currency and the resources required. Make sure you have enough of both before attempting to craft these items. If you’re looking to save some time and resources, you might also consider buying cheap Arc Raiders items online to avoid some of the more tedious aspects of farming and crafting.
4. Luck Factor
As mentioned earlier, crafting involves an element of luck. Even with the right materials, you may not always get the best result. This can be frustrating, especially if you’re crafting for a specific stat or bonus. Sometimes, patience is key, and other times you may need to accept that the random factor is just part of the process.
How Do I Know If My Legendary Gear is Worth Crafting?
With the crafting process being as resource-intensive as it is, it’s important to ask yourself if the legendary gear you want to craft is actually worth the investment. Here are a few things to consider:
Do I need this gear for my build? Legendary gear should be an upgrade over your current equipment. If it doesn’t give you the specific boosts you need for your playstyle, it might not be worth crafting.
Is the gear versatile? Some legendary items may be great in certain situations but not useful in others. Make sure the gear you’re crafting will provide value in a variety of scenarios.
Will it be useful in PvP and PvE? Legendary gear that is useful in both player-versus-player and player-versus-environment content is a good investment.
How Can I Improve My Chances of Crafting Better Legendary Gear?
To maximize your crafting potential, here are a few tips:
Focus on resource gathering: The better your materials, the better your gear will be. Spend time gathering rare materials and upgrading your crafting stations.
Upgrade your crafting skills: As you level up your crafting skills, your chances of producing higher-quality gear will improve.
Be patient: Legendary gear isn’t something you’ll craft overnight. Take your time, gather resources, and try to enjoy the process.
Crafting legendary gear in Arc Raiders is an essential part of the game for players looking to maximize their power. While the process can be complex, understanding the steps involved will make it much more manageable. Whether you're focusing on gathering materials, unlocking crafting stations, or improving your gear with enchantments, there’s always something new to learn.
Remember, crafting legendary gear is a mix of preparation, skill, and a little bit of luck. If you find yourself struggling to get the gear you need, you might want to buy cheap Arc Raiders items online, especially for those rare materials that are hard to farm. The key to success is balancing your crafting with your overall goals in the game, so don’t be afraid to take your time and enjoy the journey.
This page was generated in 0.141 seconds.
