How to make a beams and change properties?
JOELMIRMEURER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOELMIRMEURER Quote  Post ReplyReply Direct Link To This Post Topic: How to make a beams and change properties?
    Posted: 17 Feb 2022 at 7:02pm
Hi, i need make some beams and align the wall studs with vertical intersections trusses. how to do it?
My icons are different than user guide.
Edited by administrator - 28 Mar 2022 at 10:38pm
Answer Answer
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 12:26pm
Hi
All depends on your detailing approach.
If you are are starting with walls, then you will plan out your studs according to your requirements.
If this is the case you will draw face on top of your walls as a foot print for the roof and then use the roof guide tool to generate guide lines for you to add trusses as you need.
Please see Roof Tutorial
This page was generated in 0.092 seconds.
