Version 4.1.0 Release Notes:
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 4.1.0 Release Notes:
    Posted: 05 Sep 2019 at 8:13am
Version 4.1.0
  • Context diagram dimensions labels being too large has been addressed.
Roof
  • Minor Bug Fixes for spacing of trusses
  • Flat truss/joist/beam option added. New icon added to roof tool set for flat truss.
  • C Purlin has been update with an option to place/space purlins on panel/diagonal load points of a truss.
  • New Soffit configuration option added to roof overhang
  • Bug in the c purlin exports that shows zero length for c purlins in the materials sheet has been addressed.
Floor
  • Lattice Joists in Floor Tool Module has been upgrade using same features as the roof module. You can now customize each floor truss.
Beam Module
  • Beam module has been incorporated into roof module. Use flat truss option within the roof module to create standard flat trusses.
Free Tool Module
  • Auto Trim option to automatically trim profiles being generated from reference lines. For edge of a profile can automatically be extended to the edge of the web of the intersecting profile minus the clearance set in the properties.
  • Over 95% increase in performance when tooling a selection of profiles
  • Undo bug after tooling is now resolved.
  • New Feature: Generate offset guide points from references lines in relation to the profile chosen. This will help determine perfect back to back configuration.
  • Convert collection of profile into a component and free tool within the master. All instances will be automatically updated.
  • Priority 2 Tag option has been added. Green = Priority 1 to avoid Notches on webs. Yellow = Priority 2. Grey profiles are standard. If a Green intersects with Yellow, the notch is place on yellow. If a yellow intersects with standard, Notches are places on standard.
Machine Related
  • FrameCAD export template revised for Trusses.
  • FrameCAD export template for Floor module has been revised
  • FrameCAD export template for doors and windows not appearing in the export has been revised.
Global.
General.
  • Automatically renaming of Copied objects within FrameBuilder-MRD
  • Floor plan bugs have been addressed.
  • Lattice Beam icons removed. User will now use the roof module to create standard flat joists
Edited by administrator - 16 Sep 2019 at 12:32am
This page was generated in 0.186 seconds.
