Forum Home Forum Home > FrameBuilder MRD > Feature Requests
Forum Locked014:Free Tool Polish
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: 014:Free Tool Polish
    Posted: 14 Oct 2019 at 6:45am
Requestors: Pavel
Module: Free Tool and other modules
1) PDF module.
a) Every panel you generate on PDF module is with the same name - name of the SketchUP file. So every next PDF overwrites the existing. Need to generate PDF with the unique name of the group.
b) Something wrong with page orientation. Portrait works well, but landscape doesn't work properly. It splits into 2 portrait pages.
c) Would be nice to have multiple PDF generation, it means, if you select several groups it will be able to generate PDF for all selected groups in 1 click.
d) Option for printing panel's dimensions (optional), so on PDF you will be able to see height and length of the panel.
2) CSV module
a) Option to name the file only according to the name of the group (excludex name of the SketchUp file and etc.)
b) Option to select destination folder, not only by default saved in the same folder as project.
c) Option to generate several copies of the CSV files. You have designed a truss and you have 15 of them in the project. So you just put 15 and you will have a list of CSV files, like:
T-1_001
T-1_002
T-1_003 and etc.
d) Option to modify template of the CSV file. By default, as an example, for H320 machine we have this format:
UNIT,MILLIMETRE
PROFILE,S8908,Standard Profile
FRAMESET,Sample1,SampleFile
COMPONENT,GP1-1,LABEL_INV,1,500.0
d1) Our machine doesn't undertand "," separator, only "    " (tab), so I manually using CTRL+H combination replacing all commas to tabs. Would be nice to change separator.
d2) By default you have:
Our machine understands:
PROFILE(tab)DEFAULT_PROFILE
d3) By default you have:
GP1-1, takes the "1" from the group name, good to have an option not to inherit it.
3) Free Tool
a) Please activate all tools for line option
b) Button to reset colours of tagging in all panels.
Notes:
Impact: All
Actions:
Progress:0%
Implementation Date: January 2020
This page was generated in 0.176 seconds.
