Forum Home Forum Home > FrameBuilder MRD > Feature Requests
Forum Locked020: Generic Weight Estimation
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: 020: Generic Weight Estimation
    Posted: 20 Nov 2019 at 6:52am
Requestors: Pavel
Module: All. Material Costing Dialog
Can you please make a multi level dropdown menu as an option. Where you can select you strip width and thickness and it will automatically set weight per 1 running meter?
As an example, we have strip width 180 mm, with the thickness of 1.2 mm according to digital scales the weight is 1.73 kg.
So, based on this you can calculate easily any of width and thickness.
Impact: All Modules.
Actions:
Progress:0%
Implementation Date: 1/4 2020
Edited by administrator - 19 Nov 2019 at 11:52pm
This page was generated in 0.203 seconds.
