Version 4.4.3 Release Notes
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 4.4.3 Release Notes
    Posted: 22 May 2020 at 11:48am
  • Global Option to switch off center guide lines. Under Global Settings
  • Snap to center point when adding custom profiles
  • Added option to set chamfer end clearance for all modules.
  • Faster rendering times.
  • General Bug fixes
Walls:
  • Added option to overlap split nogs. Set Staggered nog to true and staggered nog spacing to 0.mm
  • Auto Stud on insertion of new wall on intersections or start end walls.
  • New Door configuration for doors place at very end of wall.
  • Auto connecting stud configuration for intersecting walls.
  • Auto wall stud alignment to floor joists
  • Option to switch on rendering of cladding based on board sizes in material settings.
Floors
  • Auto floor joist aligned to studs
  • Delete Lattice Joist Option
  • Lattice Style Joists Load Analysis Check working.
Roof
  • Auto align trusses to studs
  • Delete truss Option
  • Edit truss within a group
  • Ability to rotate roof frame profile. Square, triangle and ridge point frames.
Free Tool
  • Top hat purlins groups machine file generation fixed.
Edited by administrator - 04 Jun 2020 at 11:15am
This page was generated in 0.514 seconds.
