Wall: How to Add Pockets into a Wall Frame
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Wall: How to Add Pockets into a Wall Frame
    Posted: 23 Nov 2020 at 7:18am
1: Select Wall
2: Open Wall Toolset
3: Select Pocket Tool Set
4: Add/Edit/Move Pocket
Examples:
Edited by administrator - 23 Nov 2020 at 2:02am
Answer Answer
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 11:39am
"Hi. I'm wondering if there is a way to add a pocket to the bottom of the frame? I'm trying to cut the frame around the base plates of structural columns, but I can't figure out how to do it. Hopefully someone can help"
Try the following:
Step 1: Draw your a standard wall between the columns
Step 2: Use the Split Point Tool to add two split points on the edge of the base
Step 3: Use the Stretch Icon found in the wall module to pull the yellow stretch points on the inside edge of the bottom split points towards the bottom of the base.
Edited by administrator - 20 Feb 2022 at 6:42am
andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrew Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:44am
Answer Answer
Try the following:
This page was generated in 0.171 seconds.
