Version 4.9.1 Release Notes
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 4.9.1 Release Notes
    Posted: 01 Jan 2021 at 7:06am
Global
  • Ability to import FrameCAD XML Export into FrameBuilder
  • Ability to change user profile and machine for existing components.
  • Fixed bug for Sketchup Layout Export related to alphanumeric ordering of components names.
  • Module "Structure Information" updated with ability to search for a specific component.
  • Sketchup Layout failure to export bug fix.
  • Sketchup Layout profile schedule table show item ids related to the panel drawing.
  • Sketchup Layout panel drawings get service holes and bolt holes markings.
Grid Tool
  • New options to edit or update already drawn grids.
  • New height properties allows you to extend the grid guides in the vertical direction
  • New horizontal spacing of guide lines.
  • New on center option for Nog Spacing.
  • New option to export Wall Floor Plan to Sketchup Layout. New tags also linked to labels can be toggled on an off via Sketchup Layout
  • New special off to switch off dimples between ends on studs.
  • Sketchup Layout Floor plan gets updates showing stud positions and openings.
  • Telescopic Frame Bug Fixes
  • Wall floor plan trace new stud impact warnings. Red circle highlights impacts.
  • Option to Convert generated walls into wall trace components. Select walls and click the number 2 wall trace icon to convert to wall trace.
  • Switch off dimensions for 3D components copied to Sketchup layout.
Roof
  • Bug in Custom Truss Mode: Deleted Verticals and Horizontals not reset with option
  • Roof Guide line tool gets an update. You will now have the ability to slices a complicated hip roof into segments using the guide tool.
Edited by administrator - 04 Feb 2021 at 5:21am
This page was generated in 0.396 seconds.
