Version 4.9.7 Release Notes
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 4.9.7 Release Notes
    Posted: 08 Jun 2021 at 10:14am
  • FrameCAD Import options to force certain frames to be imported as custom
  • Tooling bug fix for nog that goes through a split header opening
  • Truss Insert Tool set can now be used to customize window/door opening headers
  • Note this is release as Beta test option for now. Enable under default wall settings under new Beta Tab.
  • Bug fix for Frame End web and bolt hole option. Spacing problem has been fixed.
Floor:
  • Bridging/Blocking profiles rules for tooling will be updated to avoid lipcuts in Joists.
Roof and Trusses
  • Bug fix for cnc export for trusses that have pockets.
Edited by administrator - 21 Jul 2021 at 2:12pm
This page was generated in 0.527 seconds.
