Version 5.0.9 Release Notes
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 5.0.9 Release Notes
    Posted: 26 Jan 2022 at 9:20am
  • Extended Machine Support
  • Option to customize hold down web holes with 1,2 or 3 holes on web.
  • Option added to each module to customize base name. E.g W as base name for Wall or R for roof or T for Truss. Naming will thus be W1, W2 and so on.
  • Sketchup 2017 Panel Drawing support removed. The only option available will be Sketchup Layout Export for Sketchup 2019+
  • Option to import Vertex XML components into FrameBuilder
  • Bug fix for renaming panel.
Roof:
  • Overhang bug fix
  • Flange Notch Tool Left and Right now works on B2B/Out of plane Trusses.
Walls:
  • Howick Split frame bug fixes.
  • Bug fix for stretch points on mono pitch walls.
Edited by administrator - 21 Feb 2022 at 5:14am
This page was generated in 0.133 seconds.
