Forum Home Forum Home > FrameBuilder MRD > Support > Tutorials
Getting started Basic tasks
Tazmeen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tazmeen Quote  Post ReplyReply Direct Link To This Post Topic: Getting started Basic tasks
    Posted: 05 Jan 2018 at 9:26pm
Basic Tasks:
Draw a Wall
Step 1: On the FrameBuilder - MRD  menu screen, select Draw/ Wall/ Draw a Wall.
Step 2: A window with Wall Properties will open up.  Select the properties that you require and click "Ok"
Step 3: Draw your wall (ensure that you draw within the green and red axis on the screen).  Once complete the size of the wall will appear on the FrameBuilder - MRD  menu screen.
Draw a Gable Wall
Step 1: On the FrameBuilder - MRD  menu screen, select Draw/ Wall/ Draw a Gable Wall.
Step 2: A window with Gable Wall Properties will open up.  Select the properties that you require and click "Ok"
Step 3: Draw your Gable Wall (ensure that you draw within the green and red axis on the screen).  Once complete the size of the wall will appear on the FrameBuilder - MRD  menu screen.
Draw 4 Quick Walls
Step 1: On the FrameBuilder - MRD  menu screen, select Draw/ Wall/ Draw a 4 Quick Walls.
Step 3: Draw your 4 quick walls by drawing a vertical line first, then drag your mouse to form a square (ensure that you draw within the green and red axis on the screen).  Once completed your walls will appear and the size of the walls will appear on the FrameBuilder - MRD  menu screen.
This page was generated in 0.648 seconds.
