Version 3.1
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 3.1
    Posted: 12 Sep 2018 at 5:14pm
1. Wall Module
1.1 Add custom tooling points for dimples, notches and others to all walls components.
1.2 Extended Header configuration for high walls.
1.3 Fix Bracing for between stud and openings
1.4 Fix Panel Drawing output coordinates for Frama Machines
1.5 Add Overhang for Gable and Shed Walls
1.6 Add Lateral Load Analysis button to quick links
1.7 Material Grade Description added to global settings for Machine file output
1.8 Max Wall Length moved from Global to Wall Properties
1.9 Added Quick cutouts to door openings
1.10 Extra Stud option at frame ends
2. Roof
2.1 Added Overhang to Hip Roof
2.2 Clean up properties to display only properties for the selected roof
2.3 Add 3 new styles of roof trusses. Parallel Chord Mono Truss, Parallel Chord Gable and Bowstring
2.4 Bug fixes for tooling points
3. FreeTool
3.1 Option to Glue profile to floor= Z=0
3.2 Fix tooling bugs
3.3 Draw guide Grid
3.4 Ability to Group and Explode Profiles
3.5 Generate Panel Documents for Groups
3.6 Generate Machine Files for Saved Group of Components
3.7 Generate Costing for Groups
4. Beams
4.1 Bug fixes for tooling points
5. Floor
5.1 Added 2 New Floor options. Standard Floor Frames and Tab
5.2 Improvement on Bridging
5.3 Staggered Bridging Configuration with Auto Generation
6. General
6.1 Ability to access Profile data file to add or change profiles under Settings Menu
6.2 Ability to access Machine File Configuration Settings for Tool Sizes under Settings Menu
6.3 Improvement on Panel and Context Drawings
Edited by administrator - 12 Sep 2018 at 11:40am
This page was generated in 0.355 seconds.
