Version 4
Post Options Post Options   Thanks (0) Thanks(0)   Quote administrator Quote  Post ReplyReply Direct Link To This Post Topic: Version 4
    Posted: 08 Apr 2019 at 7:16am
This list is currently being updated:
Walls:
Use Spacebar to change justification of trace from left, right and center on the fly
Free Tooling within walls is now possible:
 Use Sketchup lines tool or Framebuilder line tool found in the Free Profile Toolbar(Number 1 option) to draw lines on the surface of the wall frame and use the Free Profile Tools (Number 2 option)
Trace options to generate.
Pull up wall height option
New Service Hole functionality.
Trace over the surface of the wall panel with SketchUps line tool and use click the Service hole icon found in the Profile Tools to generate service holes alone the path of the line.
Floor
Lattice System
You now have the ability to analyze loads for lattice joists over a given span.
Roof
Select wall you want to align roof trusses to studs with
Specify truss positions manually
Edited by administrator - 23 Apr 2019 at 12:15pm
This page was generated in 0.146 seconds.
