Forum Home Forum Home > FrameBuilder MRD > Feature Requests
U4GM PoE 2 Mid Tier Talisman Crafting Where Value
Hartmann846 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hartmann846 Quote  Post ReplyReply Direct Link To This Post Topic: U4GM PoE 2 Mid Tier Talisman Crafting Where Value
    Posted: 1 hour 43 minutes ago at 10:24am
By the time your build starts leaning on weapon upgrades instead of lucky drops, crafting stops feeling optional. It becomes the thing that keeps your damage relevant. For a lot of melee or physical-focused setups, a mid-budget Talisman is where that shift really happens, and if you're managing your PoE 2 Currency carefully, this route makes way more sense than chasing some dream-tier craft you'll probably never finish. You don't need a perfect item. You need a weapon that hits hard, feels clean in maps, and doesn't eat your whole stash in one sitting. That's the sweet spot.
Start with the base
The base matters more than people want to admit. If the item level is under 80, I'd usually skip it and move on. You're just cutting off too many good rolls before you even begin. Spiny, Magi, and Jade Talismans are all worth a look, but the right one depends on what your build is missing. Some builds need raw physical scaling. Others need a bit of speed or a stat patch. Either way, don't grab the first thing that drops and call it a plan. A solid base gives you room to craft something useful instead of fighting uphill against bad odds from the start.
Lock in the damage first
This is where a lot of players waste money because they chase balance too early. Don't do that. Get your prefixes sorted first. Physical weapons live or die on those damage lines, so that's where your attention should go. Essences are great here because they cut through some of the randomness and let you force progress instead of hoping for a miracle. What you're trying to land is pretty straightforward: one strong increased physical damage roll and one flat added physical roll that doesn't feel embarrassing. If you hit that, you've already built the core of the item. It may not look flashy yet, but it's doing the job.
Finish without overcooking it
Once the prefixes are good enough, then you look at suffixes. Attack speed is usually the easy favourite, crit can be nice if your build scales it properly, and accuracy can quietly save a weapon that would've felt inconsistent otherwise. This stage doesn't need to turn into a science project. A simple slam can work. So can a light touch with more controlled options if you're trying to avoid ruining what you've already made. The trap is thinking every open slot has to become premium value. It doesn't. If the item gives you real damage and one or two helpful utility stats, it's already ahead of most stuff you'll pick up off the ground.
Know when the craft is done
The hardest part isn't rolling the item. It's stopping. People brick decent gear every day because they can't leave a good result alone. If your Talisman has strong phys, a useful suffix, and no total junk clogging it up, just equip it and go play. You'll feel the upgrade right away in map clear and boss uptime. That's the point. Mid-tier crafting is about momentum, not perfection, and if you ever need help getting the resources together for the next upgrade, plenty of players look at services like U4GM for currency or item support while keeping their build progression moving.
This page was generated in 0.203 seconds.
